ScottG
Sep 10, 2017Nomad
It depends on the relay. If it has a NC (normally closed) connection then you will get continuity across those contacts.
Typically a relay that has a NC circuit also has a NO (normally Open) circuit as well.
There's usually a diagram on automotive relays. It will show you how it works.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
