THenne1713
Sep 11, 2017Explorer
Normally, would say a Disconnect SWITCH or FUSIBLE LINK WAS BAD/ BLOWN, but yours (intermittent) sounds more like a loose wire.
base1957 wrote:
1997 Winnebago Vectra Drove home. Turned MH off. Wouldnt start.
Odd Part is:
1. battery cables good and have continuity.
2. Took battery and had it tested. is GOOD
3. Get no power to front of bus. No horn, no lights, and no ignition.
HERES THE ODD PART: WAS TRACING THE CABLES FROM BATTERY AND TRACED THEM INTO THE BOX MARKED "BATTERY MODE SOLENOID AND DISCONNECT RELAY LOCATED IN SIDE HERE"
Opened that box up and when I would hit try and reset the
"Coach Breaker Panel" fuse... I could at times get the lights , horn , and even ignition to turn on. But when I would try to turn the key to the start position... wasnt enough power. As i said the battery has been checked and is good. Now im back to where nothing will come on.
thanks in advance
john
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
