- gboppExplorerI agree with Old-Biscuit, I think you have a foreign object blocking the drain.
Is the toilet plugged up or, when you try to drain the black tank nothing comes out?
You may have to run a snake up the dump valve. But, be ready to remove the snake and install the slinky in about .003 seconds, or less.
Did you try a Rinsing Valve? - Old-BiscuitExplorer IIIMine has same two (2) 45* elbows and NEVER plugs up.
You missing anything.......kids toy, comb, brush etc. ?
Need to run a 'snake' down thru toilet into black tank.
Wouldn't use Drano or any other chemical drain cleaning........toilet line is 3" so you have a large blockage. Mechanical means of clearing vs standing pipe of chemicals - agwillExplorerDrano and lots of water!
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
