mleekamp
May 01, 2022Explorer
Another option, as long as the factory headlight assembly is not broken, is to buy the $30 (may cost more now than a few years ago) headlight restoration kit at your auto parts store. I tried it a few years back on an older vehicle. Basically, it's a paste, with some sort of grit, and you use circular pattern to mill off a couple thousands of an inch of the face plastic material. It's a multi step process but I saved money, and 3 years later they still look good. In the end, it allows you to remain using your factory lighting assembly but remove the yellow haze. Worth checking out for those in that situation.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
