Skibane
May 01, 2022Explorer II
mleekamp wrote:
Another option, as long as the factory headlight assembly is not broken, is to buy the $30 (may cost more now than a few years ago) headlight restoration kit at your auto parts store. I tried it a few years back on an older vehicle. Basically, it's a paste, with some sort of grit, and you use circular pattern to mill off a couple thousands of an inch of the face plastic material. It's a multi step process but I saved money, and 3 years later they still look good. In the end, it allows you to remain using your factory lighting assembly but remove the yellow haze. Worth checking out for those in that situation.
Yep, lenses that are fogged with age don't let as much light through - and the light that does get through tends to be dispersed in all directions. So, you get more glare in unwanted directions, and less light in the desired direction.
I've used the Sylvania restoration kit several times, and really like it - Makes a very fogged lens look almost brand-new again.
