KendallP's avatar
KendallP
Onan 4.0 BFA - Hot Rodded! But...
OK. "Hot Rodded" might be just a wee bit of an exaggeration, but...
I'm pretty proud of my tuning job... regardless of the lack of any real skill required.
So I began to notice the old '86 Onan, even after a complete tune-up, would not hold voltage well with much of a load. In fact... as I recall, I believe my first indication may have been a high charging voltage from the old Magnetek 6300.
I got a hold of the service manual and went through the steps, i.e. first the idle, then the main mixture screws. Problem still there.
So the remaining, most likely candidate was the governor spring. If almost 30 years old... then... yeah. Might be a bit worn. But all the digging in my pockets yielded no fruit. And patience is for wimps and smart people. My family needed to go camping, darnit!
Now many of you know that this old Onan relies on RPMs to determine voltages and frequencies. Not ideal. Just ask Ol' Mex to weigh in on that. You might be in for an earful.
The manual calls for adjusting the governor for an idle voltage of 127 and frequency of 61 with the engine warm. Tolerances are basically 5% on either side of 60 hz, i.e. 57-63 hz with a maximum, no-load voltage of 132 and a minimum, full-load voltage of 108. When it comes to my A/C pump... I don't like that 108 figure one bit.
Now there's an adjustment for the spring. But I figured that would only raise the idle voltage. A weak spring can't really be adjusted away. Unless...
It occurred to me that the spring attachment location on the governor arm is adjustable. So why not use a little, basic physics, i.e. leverage! Worth a try, right?
Long story short... with a little trial and error... using my Kill-a Watt as a guide... with a warm engine... and PRACTICALLY REGARDLESS OF LOAD... I was able to garner... get this...
~128V (verified with another meter)
59.9-60.1 hz
Power Factor - 1
My A/C pump never had it so good. And the Magnetek appears to be very happy, as well.
Now sure... I'm guessing my sine wave is not smooth as a baby's behind. But this is definitely good enough for the girls I go with!
With one exception...
A bit of a surprise...
Under a heavy load, i.e. A/C and 1500W electric heater (my method for exercising 'er,) the voltage actually CLIMBS into the 132 mark. The frequency remains near 60.
So...
I know the manual states that 132V is the upper tolerance... and, to a degree, I generally like more voltage than less, but...
What do you guys think of this voltage?
Gramps (Mex.) I'm expecting you to weigh in, here.
  • I guess the questions are did the generator do it before and what is the effect of the high voltage on the various devices you run? I usually don't feel good pushing the limits, especially with older equipment.
  • j-d's avatar
    j-d
    Explorer II
    I think you will shorten the lives of at least some of the devices you're powering at 132VAC.
    Seems odd to me that the hZ at a higher voltage is lower than at a lower voltage. As you mentioned, BFA Cycles, RPM, and Voltage are all tied together. Basically if all you have is a Tachometer and can get around 1800, a Voltmeter and can get 120, or a Scope and can get 60, your BFA is turning about what it should.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
