ImaginaryNumber's avatar
Jun 17, 2013
Onan 4000 Microquiet KY no start - Oil level switch bypass
My 2004 Trail Lite 235s has an Onan Microquiet 4000 KY generator which has always started right up, but now won't start.
The rig has been parked for almost a year on a slight incline with the rear of the genset lower than the front. I have periodically exercised the genset, but a couple of months ago it would not start. My current project is to get it started and tuned up for our summer vacation.
Model: Onan 4000 Microquiet - 4KYFA26100K Spec K
S/N: D030493001
The genset cranks but fails to start. The fault code is 36.
Inspecting what I can see without removing the genset from the motorhome, looking through the throat of the air intake, the carb looks very clean, with no evidence of varnish. I verified fuel flow, drained the bowl, added SeaFoam liquid to the gas line, sprayed SeaFoam spray into the air intake, and changed and gapped the spark plug but it still won't start.
I was wondering if having the RV parked at an angle for an extended period might be activating the low oil switch. How can I identify the low oil switch wire from an accessible connector? The connector above the solenoid is the only one I see.
Also, the LED light on the remote control does not work.
Does anyone know how to access the low oil sensor wire from an accessible connector, or have any other ideas to get the genset started? It only has 10+ hours on it.
Or alternatively, any suggestions for service in the Boulder, CO area?
Thanks
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
