Jdfire12
Apr 08, 2017Explorer
Onan 4000 microquiet randomly shutting down
I have an Onan 4000 microquiet model #4KYFA26100K. It will start and run and generate power. BUT, it randomly shuts down. Might be after ten minutes or two hours or 10 hours. Lately the best I can get is an hour or so, usually less. It has 2000 hrs on unit. I have changed fuel pump/ filters(twice), new fuel lines from tank. New spark plug and air filter. Oil is fresh and full. When unit shuts down, I've noticed that there is often not power to fuel pump until it's cooled down. Not always the case, but often. The Gen is located in a compartment, but I've experienced this in cool weather as well as hot. Unit does get adequate airflow and since it has 2000 hours, it's obviously run quite well in this space for sometime. I don't think it's the coil, since a faulty coil or coil wire shouldn't cause a no power to fuel pump issue at restart. I'm leaning toward the control board being the issue, just want some feedback before I invest $300 for a new board from Flight systems
