Mike20657's avatar
Mike20657
Onan Maquis 7000 in 93 Holiday Rambler Fuel Pump Issue
Hello,
I have a problem locating the F2 Fuel Pump fuse on my Onan Marquis 7000 Model # 7NHMFA26106C in my 93 Holiday Rambler
I have replaced the bad pump with new pump, no power on + wire to pump which I suspect is a blown F2 Fuel Pump Fuse.
Unit will start if cranked and spraying fuel down carb throat but no start with pump directly powered.
The Fuel, Ignition and Choke are all on this circuit so I need to locate Fuse to eliminate it as a potential reason.
From Net research it should be in line outside on right of control panel but it isn't.
Any help would be appreciated.
Mike
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
