Mike20657
May 04, 2014Explorer
Kpackpackkelley,
Thank you, this helps in a lot of ways funny thing is in this manual it shows the F2 fuse located in the cover of the control panel but on mine cover has nothing other than F1 Fuse and Start Switch.
Must be a year change thing or something along them lines.
I we assume it is a Spec D version then Fuse more likely is on back of Air Cleaner adaptor. Guess I am going back out there and see if I can locate it.
Checked it nothing attached to back of Air Cleaner, guess I will have to trace all the wiring out until I find the fuse, doesn't make sense it would be inaccessible, maybe someone may know where it is located.
In looking at Schematic Fuse F2 protects the Fuel Pump, K4 Relay and Choke
Mike
Mike
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
