enblethen
Mar 15, 2018Nomad
Even though you have checked the oil level, if your Onan has an oil level switch it could be bad.
Can you tell if oil is foaming? This could also cause oil level or oil pressure switch to shut it down.
Along with "whemme" post the fuel pump could be sucking air through decaying rubber line.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
