path1 wrote:
(Hate to tell on myself). Years ago when we were starting out and our 1st RV was new to us, I was told the break away switch would lock up the wheels if cable became disconnected. I thought great, what a slick anti-theft device. Parked RV at seasonal campground and came back next weekend and wondered why my battery was dead. Charged up battery no problems, but I'm sure it shorten life of battery.
You can probably do all kinds of tests to see if any damage. I use an "old style" compass and see if needle spins around when brakes applied (being my ears aren't so good anymore).
You need to do a pull test with 7-pin disconnected and breakaway pin out again. Just hearing the brakes work or that hum/whine at each wheel with the brakes on and trailer stopped does not tell the tale.
I have a brake job coming up so I know that. I get the 12amps ok, the voltage is good, get the hum/whine. You can hear the brakes apply. But the trailer has "no brakes."
Various possibilities, all expensive, but never mind that--the point is you have to do the pull test to see if the brakes actually stop the trailer from moving, both with the breakaway test as above, and also with the brake controller and 7-pin way with no truck braking and the manual slider on the brake controller.
