Snowman9000
Nov 06, 2014Explorer
enblethen wrote:
You need to look under the correct type of wire. SAE multi strand and marine wire is smaller diameter then building style wire either stranded or solid.
If you look at the NEC building wire is only seven strand for stranded. It is .061 inches in diameter.
Here is listing for automotive SAE wire and MarineSAE wire sizes
I normally drop one connector size for SAE automotive and marine wire.
Supposedly the vendor I used sells high quality AWG cable. So I looked at that table, and taking their overall 6 AWG OD, less 2x the insulation, I get .212. Big difference from what I got. Hmmmm.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
