- owenssailorExplorerEarlier this year the wire from our batteries to the converter failed. No battery power to anything in the trailer ie they were totally disconnected. Hooked up the Honda 2000 It ran everything in the trailer including running the slide back in.
- owenssailorExplorerDuplicate
- wa8yxmExplorer IIIDepends on the slide and the converter.. A small converter say a 30-45 amp may not have the "Oomph" to move the slides without battery assist.
or it might.. - BFL13Explorer IIThe Lippert electic slide spec for ours calls for a 30a fuse. The converter has no trouble running the slide with no battery as long as there is a converter-battery path.
Jaycos have a little notice by the slide switch saying it needs the battery connected. That seems to be only due to the broken path with the battery out. (Jayco owners have confirmed that in previous threads about this) Vice grips as posted earlier will solve that. - j-dExplorer IIWhat size of Fuse/Circuit Breaker protection is wired to the Slide Motor(s)? That'll give an idea the current requirement you're up against. Personally I would not expect a Converter/Charger to shoulder that load.
- 2oldmanExplorer II
CanuckCamper29 wrote:
Try it the lazy way first..let us know if it worked.
Going to lug out my batteries.
In place of batteries you may consider a 12v battery charger. - pianotunaNomad IIIHi,
If you fully charge the batteries and then disconnect them they can be left in place all winter. No need to transport them to a "warm place". - CanuckCamper29ExplorerSounds like my "lazy" approach isn't worth the trouble. Going to lug out my batteries.
Thanks to all. - RoyBExplorer IISome slides require that extra boost from the battery to work smoothly. You can always substitute your truck battery by nosing up close to the trailer battery tray and a JUMPER SET to let your truck start battery help out some...
Be careful with POLARITY of battery cables and especially those cables just hanging where the trailer battery was connected. I would put sandwich baggies over them to keep from shorting out to frame ground somewhere. If they short out just for a small spark you will be looking for some fuses to replace in your trailer.
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
