ewarnerusa's avatar
Nov 25, 2014
Opinions on my battery charging profile (solar)
I am curious about what others with battery charging expertise think about what I'm doing to my batteries. Am I damaging them or shortening their lifespan?
Quick background, I installed 280 watts of 12V solar panels with a fully programmable Morningstar Tristar 45 controller on our new TT in 2012. At max sun I can see 15A from the panels. It had OEM 2x12V batteries that I swapped out for 2x6V Costco GC batteries in 2013. I installed an inexpensive ebay 1500 watt PSW inverter in 2013 that does not like to operate at voltages above 14.8-ish volts. So I've utilized the programmable features of my Morningstar to accommodate this, but I'm wondering if my batteries will suffer from not enough 14.8V+ charging.
My normal charging profile has 14.4V for the bulk and absorption setpoint. It will drop from absorption to float when PMW duty cycle drops to <15% for 10 minutes. I have voltage sense wires and temperature compensation, but I have it programmed to not do the temp compensation at lower than 70 degrees F. This is because I don't want the controller charging at higher than 14.4V during normal use so it plays well with the inverter. I have also programmed an "equilization" to occur every third day at 14.9V with the same temperature compensation cutoff. So when the sun is bright I hit the batteries with up to 14.9V for 3 hours every 3rd day. My logic is that this at least gets the batteries some 14.8V+ time while hopefully minimizing the impact on being able to use my inverter. During winter storage, I change the temp compensation cutoff to much colder since the TT/inverter isn't in use. I think it have it adjust down to 32 degrees F.
Do you think my 6V Costco GC batteries are getting enough charging to stay healthy?
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
