You have a STRING of AMBER lights across the top. On one end or the OTHER END. an incoming pair of wires feeds the string power when the lights are supposed to come on.
Take the cover off one end light. Then unscrew the base. If that light has only two wires connected to it, put it back together then go to the other end. Do the same thing.
Electricity is invisible so you can't stare it down and embarrass it to show itself. You need to go to the parts store and buy a TEST LIGHT. They are CHEAP.
One end of the test light has a clip. It needs shiny trailer metal to clip to. Painted don't work.
Touch the point into a connection at that light. Does it light up?
This is as far as I go until I know I am not callusing my fingertips for nothing. When you get the above done, come back for Chapter II
