wopachop
Jul 29, 2019Explorer
3 tons wrote:Can you explain more por favor? Does the crack itself fill with a somewhat conductive liquid causing the hot and ground to tickle each other?Revolver wrote:
Hello,
When I plug my electric cooktop into the outdoor GFCI outlet, the GFCI trips. The cooktop is rated at 1000w according to the label. Do those GFCI outlets have a lower amperage rating than normal?
Thanks,
Ray
No, it sounds more like a small amount of internal leakage inside the cooktop, possibly from a cracked element insulator - the GFI is likely reacting to this worn condition..
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
