cavie
Jul 06, 2019Explorer
midnightsadie wrote:
might check wire size going to these units.
50 year Master Electrician. I have no reason to check the temp of my breakers. If it does not trip don't worry about it. There is absolutely no reason for a panel to over heat unless it is over loaded or you have a low voltage condition. Be sure all connection are tight. Stop using the fan and fix the problem if there is one.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
