CA_Traveler
Jul 06, 2019Explorer III
jolooote wrote:This is not uncommon. 30A rigs have larger wire with less voltage drop and 50A rigs have even larger wire with even less voltage drop as does their pedestal plugs.
Didn't know you could run an AC on only 20 amp breaker. Voltage at the AC unit always drops below 106 VAC. What is the AC volts at any outlet in the rig when the AC's are RUNNING? Years ago, I tried to run a single AC at a 20 amp only Ckt. campsite. Volts dropped to only 104. I ran it any ways. Two weeks later the AC compressor went out.
And voltage doesn't drop to 106V with adequate wiring assuming the GC distribution system has good voltage and that includes a 20A pedestal.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
