SoundGuy
Dec 29, 2016Explorer
merc1100sc wrote:
I have two Yamaha EF2000is inverter generators that I plan to use to power the camper. Will these two, bridged together, run the AC, lights, etc. with causing harm to the generators or any any electrical components?
Be aware that the Yamaha EF2000iS doesn't play well with any Progressive Industries EMS as detailed in this disclaimer so if you're protecting your rig with one of these units you'd want to remove it from the circuit before powering your rig with these gensets. Can't say whether Yamaha has solved this issue with their newest version of this genset, the EF2000iSv2. If you don't use an EMS while running on shore power (a mistake IMO) then this wouldn't be an issue for you.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
