1320Fastback
Dec 29, 2016Explorer
I have two of the same gens and the Yamaha Sidewinder parallel adapter and it powers the AC on my 2015 SandSport just fine.
I've read the new V2 have a much cleaner sine wave for sensitive electronics.
Being a mechanic I must say these gens are very easy to work on as far as carburator cleaning. Pop the back cover off, remove the air filter housings it, remove the studs that hold the carb to motor, clean and put back together. Probably a 10 min job once you've done it.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
