SoundGuy
Dec 30, 2016Explorer
merc1100sc wrote:
I suppose once summer gets here I should try the AC along with other devices I may be running and see how it goes. The only other major draw I could see using at the same time is the microwave.
There's absolutely no need or reason to subject your genset(s) to significant load by running any more than one high load device at any given time. It's called power management - if the A/C is running when you want to use the microwave for a few minutes just dial back the A/C thermostat so the compressor kicks off and remains off while you're using the MW ... same approach we used when my wife wanted to use her hair dryer. If I were in your shoes I'd sell one of those EF2000iS gensets and use part of the proceeds to add the aforementioned Micro-Air Soft Starter Kit to the A/C which will allow it to run on just one EF2000iS. K.I.S.S.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
