landyacht318's avatar
landyacht318
PD9245 and Lifeline GPL-31XT testing
I just acquired a Progressive Dynamics PD9245 converter to specifically charge a New Lifeline AGM GPL-31Xt at 125AH capacity.
I tested the converter tonight on a different battery, and saw Voltages, read on two different voltmeters, showing 14.5, 13.7, and 13.3 when forcing the different 'stages' Via the remote pendant.
These are all 0.1v higher than it is Supposed to be.
I guess both voltmeters can be reading a bit high. Was just wondering if others see higher than the specified 14.4V?
I also played with the voltage pendant enough that I did not see how long it would hold 14.5v on its own before reverting to 13.7 and then 13.3v.
It was kind of neat pressing a button for 14.4/14.5V.
The Fan does not really come on very much or very fast, but there is a persistent whine that will change tone when different loads are applied.
I did briefly see 42.5 amps when I first forced Boost mode. Unfortunately I had the depleted battery on a 12 amp charger for an hour before hooking it to the PD9245 and it decided 13.7.
I'm taking the new lifeline to ~50% tonight and will give the PD9245 a workout tomorrow to see how it does.
Having RV issues? Connect with others who have been in your shoes.24,297 PostsLatest Activity: Aug 08, 2025
