mchero's avatar
mchero
Pex fittings on our 07 Fleetwood
I have replaced the shower faucet in our 07 Discovery. I noticed that the PEX fitting are not the standard big box store fittings. Were does one purchase these fittings?
Only PEX I have worked with was at home. I used shark bites, VERY EASY!
The PEX in my fleetwood looks like a plastic sleve is slipped over the outside of the pex, fitting slipped into end & that sleve appears to be holding\clamping te PEX to the fitting.
When replacing the shower faucet I had issues with those little rubber seals that fit inside. I'll post PICS if needed.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
