Sort By
- OldmeExplorerThanks for the info.
I am looking forward to your pictures and observations. - Bill_DianaExplorer
dougrainer wrote:
I do NOT like the idea that they do NOT remove the top AC units. That is one place you DO find rotted areas when replacing a roof the CORRECT way. AND, you replace the AC seals and the other appliance mounts. The CORRECT replacement, you replace the roof vents(vent and refer) completely and the sewer vents completely. The only thing not replaced completely is the TV antenna/Sat dome. NOT removing the top appliances is NOT doing the job correctly. The added cost of those parts is less than $200. Regardless of what the FlexArmor shop states. Now, if they give YOU the choice between cheaper and the job done correctly at a higher cost, then I am OK with it. Doug
Doug....
They do remove the AC unit...spray the roof.....insert a new AC seal....and then reinstall the AC. Im not sure what you are saying above.
Bill mlts22 wrote:
From what I read, if a skylight or vent needs replaced, it is just cut out, the new one put in, then resprayed around the new area. I consider this the biggest downside... but no solution is perfect, and ever since RV makers stopped making rigs with reliable aluminum roofs, almost anything is better than what we have now.
Yes, and if you do NOT live in Florida, what do you do then?? Doug- I do NOT like the idea that they do NOT remove the top AC units. That is one place you DO find rotted areas when replacing a roof the CORRECT way. AND, you replace the AC seals and the other appliance mounts. The CORRECT replacement, you replace the roof vents(vent and refer) completely and the sewer vents completely. The only thing not replaced completely is the TV antenna/Sat dome. NOT removing the top appliances is NOT doing the job correctly. The added cost of those parts is less than $200. Regardless of what the FlexArmor shop states. Now, if they give YOU the choice between cheaper and the job done correctly at a higher cost, then I am OK with it. Doug
- mlts22Explorer IIFrom what I read, if a skylight or vent needs replaced, it is just cut out, the new one put in, then resprayed around the new area. I consider this the biggest downside... but no solution is perfect, and ever since RV makers stopped making rigs with reliable aluminum roofs, almost anything is better than what we have now.
- Bill_DianaExplorerHere is my undstanding as to what I can expect when they take my motorhome into the RV Roof shop. They will inspect the roof to determine if the old rubber needs to be removed. They will examine for soft spots that may necessitate plywood needing replaced. All vent covers and caps will be removed, including the AC shroud, refrigerator and sewer vents. All caulking will be removed. All the prep work is done on day one. The price does not include replacement of the shower skylight. They will replace the skylight if you want and only charge for material. Or they can coat the skylight if you desire. I'm keeping the exiting skylight and not having it sprayed.
On day two they spray the roof and install all new vent caps and covers. They do not spray the AC shroud...simply install the old shroud . They will spray down the sides as far as you desire.
They told me the new roof will add about 150 pounds to the RV. David told me the new roof will help some with the heat of the sun and also deaden the sounds on the roof some.
Hope this answers some questions. Please let me know if you have any more questions. - The product is a neat idea. One of the things that came up a few years ago on the forum was this------ It appears that they FlexArmor the roof vents and other items except the Roof AC's. IF the top appliances are FlexArmored, HOW to you remove them if they get damaged and the frame and such needs replaced??? Do you have to chisel them out? Which then destroys the advantage of the roof coating. IMO, they should do what ALL roof repairers do---they remove the existing top hardware and FlexArmor the roof and then install the top appliance/Hardware and seal. They can do the job quicker and cheaper if they do not remove all the roof top components. Doug
- mlts22Explorer IIWish they would find more application spots than just the Florida location. I know that in Texas, the locals would beating down a place's door so they can get their rig done with this, because the 100 degree summer heat and UV destroys caulk and seals pretty quickly.
- oldtrojan66ExplorerWould it be more foolish than normal to assume that as long as the existing rubber roof is left in place, provided it is sound, just thin? I'm wondering if they strip off the old rubber, or spray over it? thanks
BurbMan wrote:
If I can ask, what's the cost of this compared to replacing the rubber?
Sure...no problem. I have been pricing roof replacements for the past 12 months. Back home about 35 miles north of Philadelphia I had a quote of $5,000 to $6,000 and possibly more if plywood had to be replaced. I called a place in Sanford, Fl and they have some sort of spray on roof and they kept increasing the price and finally gave a quote of $6,500 and they said it could even be more. I had another fella from the east coast of Florida give be a quote of $4,700 to $6,000 for a rubber roof. I had 2 or 3 other quotes all in the same price range.
RV Roof is doing the job for $4640 with a written lifetime warranty that stays with the vehicle. Having met the owner, David, and having the opportunity to visit his shop to see the finished product has made me very comfortable with my decision.
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: May 01, 2025
