dougrainer
Jun 24, 2017Nomad
Take the Oven tstat knob off. Insert a small piece of paper inside the "D" shapped hole in the knob. This will cause the knob to NOT fully be inserted into the tstat metal shaft. The usual problem is, when you push the knob IN to light the pilot, you cannot get it fully pushed IN to allow the pilot gas flow. By shimming the knob you get the shaft to fully push IN and the gas flows. VERY common problem and easy fix. Doug
