Ron3rd
Jun 24, 2017Explorer III
dougrainer wrote:
Take the Oven tstat knob off. Insert a small piece of paper inside the "D" shapped hole in the knob. This will cause the knob to NOT fully be inserted into the tstat metal shaft. The usual problem is, when you push the knob IN to light the pilot, you cannot get it fully pushed IN to allow the pilot gas flow. By shimming the knob you get the shaft to fully push IN and the gas flows. VERY common problem and easy fix. Doug
Good info, thanks. I recall reading a while back a guy did the same thing but he used a small piece of aluminum foil to accomplish the same thing.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
