Turtull's avatar
Turtull
Please help assess my 12v system!
Would really appreciate it if some folks with electrical experience could comment on my set up. I don't have an inverter or solar or anything just an isolator and aiming for a really simple setup.
I think that the fuse between the auxiliary battery and the fuse block (via the main switch) needs to be swapped out to 50 amp, because I have used 8awg wire to the fuse block?? I was going to use 4awg through out but had difficulty getting the right ring terminal sizing and connections and that's why there's different gauges in there.
Any other issues that anyone can warn me of? Thanks in advance!!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
