Yosemitebobr's avatar
Yosemitebobr
Plug to Camper problem, it's loose in its receptacle on RV
So, hoping the statement in subject line is clear, but if it isn't. I noticed today that the 50amp plug on my main service cable is loose when I turn it into the receptacle on the RV. Can this be tightened by bending the electrical tabs on the receptacle in the RV, and if so what way should I slightly bend them, in or out?
  • The weight of the straight twist lock connectors is a big factor. Yes, you can try to bend pins. Doubt whether it will last.
    Most twist lock connectors are made of better material. They do not normally show burnt marks on pins. The end that becomes loose is on the cable. Replacing it with a 90 degree, hard to find connector can reduce strain on pins.
  • Sometimes a picture really doesn't help, but I'll get one and send it next. Best explanation I have is pull or plug your main cable into your RV and note how tight it is, mine is extremely loose when I plug it in, not normal. All parts look good just too loose.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
