If people are stupid enough to do that, then they are too stupid to take advice to install a lock out, or what ever, to prevent electricity from going backwards down the line.
For me, if electricity goes out, I'll start one Honda 2k and run an extension cord from it to the fridge.  That's the most important inside house appliance I need to use.
Since this is an RV board, probably most on here have an RV of some sort, as I do.  I call it my escape pod in times of emergency.  If it's too cold, or too hot outside and the power is off, I'll just run generator power to the RV like I would if boondocking.  I then have heat, A/C, hot water, etc until the power is back on.  I would still run an extension cord to the house refrigerator.
PaulJ2 wrote:
philh wrote:
excretion cords?
Even if you meant extension cord, you're going to have to explain how connecting something via an extension cord can back feed the grid.
The way to back feed the grid would be using a generator with an extension cord with a male plug on both ends ( suicide cord ) plugged into a house wall outlet feeding half the house.
