opnspaces
Apr 21, 2015Navigator III
RJsfishin wrote:
Quote:
As someone else said in the automotive world they switch the ground, but in this case you need to properly disconenct the positive to be safe.
Where did that BS come from ?
That was one of the things I learned in the electronics classes at the manufacturers regional training center when I was a tech. The claim was that by disconnecting the negative side of the load there was less arcing hence the components would last longer. I don't know whether that actually pans out in real life, but it is what I was told is the way they design their cars. When I think about it now though, I bet they were referring to the switching that goes on inside circuit boards and not the large loads like the starter or headlight switch.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
