ashnic's avatar
ashnic
Positive or Negative to Battery switch
Just got my Torx box installed and my battery switch. Wanting to wire it up tomorrow. I believe I know (negative) but thought I would ask do I put the switch on the Neg or pos? Thanks for your help guys..
  • Almot's avatar
    Almot
    Explorer III
    It's usually Pos.
    Think of Neg as the ground, makes no sense disconnecting it when it's literally sitting on it. As the boater noted, there is more risk to make a spark if Pos remains connected. It will "work" either way, but switch on Pos is better.
  • On my MH I put my battery cut out switch on the negative side.
  • Bottom line is it doesn't really matter on a trailer - both work, and you can argue it either way. I came out of boats, and I think positive is the best way to go as there is no "potential" voltage anywhere - can't hit anything hot and make a spark ....
