- TeetonExplorerHoly crap!!!Put one on both all ready.. :)
- TlaudenExplorerPositive, that way there is nothing hot anywhere in case of accidental grounding...
- Old-BiscuitExplorer IIINegative shuts off ALL loads.
Positive, depending on where installed, can still have parasitic loads (LP detector, radio/stereo) and tongue/landing gear can still be powered)
SO........
Put it where it works for you. - BobboExplorer IIITheoretically, the positive is better.
In practice, either one works fine. - ScottGNomad
Bill & Kate wrote:
MEXICOWANDERER wrote:
Democrats put it on the positive circuit
Republicans put it on the negative circuit
Wow- you have that exactly backward ... LOL
No, that sounds right. - Bill___KateExplorer
Wow- you have that exactly backward ... LOL - MEXICOWANDERERExplorerDemocrats put it on the positive circuit
Republicans put it on the negative circuit - SCVJeffExplorer
WyoTraveler wrote:
But think of the debate you could start....Almot wrote:
It's usually Pos.
Think of Neg as the ground, makes no sense disconnecting it when it's literally sitting on it. As the boater noted, there is more risk to make a spark if Pos remains connected. It will "work" either way, but switch on Pos is better.
Interesting. Don't those little electrons fly off the atoms and really come out of the negative terminal and go back in the positive terminal?:B Either way will work as long as the circuit is broken. Don't take this serious, just kidding - An exposed switch such as a knife style I would put on the negative. Especially if in a metal box. Otherwise a standard insulated switch I recommend putting on the positive to stay with the existing conventions of switches and fuses to be on the hot lead.
- WyoTravelerExplorer
Almot wrote:
It's usually Pos.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Jan 18, 2025
