mtofell1ExplorerFeb 14, 2016Power AwningSometimes, I'm not such a fan of automation and advancement. Perfect example is the power awning on my new 5th wheel. I really liked the old style spring loaded awnings but I guess now I just get to...Show More
Big_KatunaExplorer IIFeb 15, 2016My A E is supposed to dump but it doesn't. It loads up in the middle.Mine doesn't have a knob its spring loaded on the aft side. What I observed is that if you run it all the way out, the sewed seam makes a valley that collects water. If I retract the awning just an inch or so the seam is on top of the tube and water doesn't pool anymore..it runs over the edge and doesn't pool up. Sometimes I'll throw a rope over the dump arm, pull it down and tie it off.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringPower AwningNewbie power question12 Volt Power Issue
