mtofell1
Feb 14, 2016Explorer
Power Awning
Sometimes, I'm not such a fan of automation and advancement. Perfect example is the power awning on my new 5th wheel. I really liked the old style spring loaded awnings but I guess now I just get to...
mgirardo wrote:
We really enjoy our electric awning. Ours does not have a wind sensor, so it stays out unless we pull it in. From the factory, our awning was basically parallel to the ground. When it rained, the water would collect and then one corner would lower to dump the water.
After a couple rains, I decided to slant the awning. Ours has 6 positions. I usually use the lowest or next to lowest. It isn't nearly as slanted as a manual awning can get, but rain just rolls off it.
Our summer seasonal camp site is located directly across from a farm and we always have a breeze. We purchased a set of anchors with a large spring that goes between the anchor and the strap that connects to the awning. That allows the awning to gently move a little if in higher winds.
I have seen people use PVC pipe to create legs for the power awning. We did not do that, because if the awning does move and the PVC slips off, they'll be projectiles in strong winds.
Check to see if you can slope the awning. Different power awnings have different ways to adjust them. Our does not have any knobs, just buttons that get pushed in and then the arm slides to the next hole.
-Michael
