CA_Traveler
Apr 08, 2021Explorer III
valhalla360 wrote:With sustained loads like A/Cs the draw should be limited to 80% or 24A. At 30A sustained the plugs heat up and this is a common cockpit problem with a 50A RV on a 30A pedestal.
If not make sure to limit the loads when on 30 amp.
Agree with other posts - you'll have nothing but problems until bright shinney new plugs are installed.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
