Showbill1's avatar
Showbill1
Power converter
Hi everybody I’m new here hope you can help me I ave a motorhome Fleetwood soutwind 206 and my house battery won’t charge I tested tehe charger and it’s bad so the charger is a WFCO 9875 it’s a 75A so the thing I want to know can I put a 30A instead of the 75A
thank you for your answer
  • When my WFCO 100amp converter croaked towards the end of the warranty period (2 years) WFCO replaced the unit no charge (I installed) While I was waiting for the unit, I used a 15A auto charger to run the RV - didn't have any problems (I was docked). The replacement unit has been running just fine for the last 12 years.
  • you can also switch brands  and go to a Power dynamics charger, I don't know if I would step down the charge amperage though.  what I would do is make sure what ever you buy has a good Li mode, not auto detect either.  that way in the future if you decide to go to LiFePO4 batteries it is easy or if you sell it, it is a selling feature.
    • valhalla360's avatar
      valhalla360
      Navigator
      Agreed, WFCO are pretty well established to be junk.
      Most of the newer units have a lithium mode, so it should be no cost to get one that can handle lithium or lead acid and when you replace the batteries, lithium makes a lot of sense. Lighter and for the same amp-hr rating, they have double the usable amp-hr because you can safely drag them very low. Lead-acid don't like to be below 50% charge.
      75amp charger is overkill for almost all situations. It can also be a hassle if you are on a 30amp shore power pedestal. If it decides to max out, it's going to pull 1000-1100w. If the aircon is pulling 1500w, that doesn't leave a lot of room for other misc loads before you start popping breakers (30amp is 3600w peak but only 2800w continuous load).
      Even if you have a massive 400amp-hr battery bank and it's dead, one overnight with a 35amp charger will have them full by morning. So unless you regularly drain the battery bank and want to fast charge with a generator, not rally any benefit to the big charger.
      When our 55amp WFCO failed, we switched to a 35amp powermax and have been satisfied. Nothing 12v DC that runs for more than a few seconds pulls anything close to 35amp, so if you are running the stabilizers/slides, it pulls the excess amps off the batteries and within a few minutes, the charger has replaced it. For lighter continuous loads like the lights, I've never seen more than 10amps (usually 5-7).
      • StirCrazy's avatar
        StirCrazy
        Moderator
        and see I would keep the 75 amp capability if I could, just for that faster charging ability.
  • Yup, it will just take 60% longer to charge the batteries the same amount.
      valhalla360
      Navigator
      But unless you are boondocking and charging a big battery bank from near dead, does it matter?
      If in a campground, for a single overnight, you typically will have 14-18hr of charging from the pedestal. 14hr at 30amp is 420amp-hr replaced.
