D_MAX's avatar
D_MAX
Power cuts out when pump runs (on DC)
I have an new electric issue that I need to troubleshoot tomorrow and am looking for advice.
On DC (2 x 6V) lights are good, power shows full (also metered at batteries 13ish). When the water pump kicks on it dramatically slows down, the lights dim, then it’s like the power is cut as the propane detector beeps (the low power beep) then everything clicks off. Then everything comes right back on and lights are bright as can be.
Checked the voltage at the batteries while this happens and it shows a slight drop. On shore power no problems at all. I didn’t have a lot of time to dig into it so far, but assume it has to be either something in the converter, or batteries.
Thoughts?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
