DrewE
Jun 18, 2018Explorer III
136V is pretty high nominal voltage, particularly with a little bit of voltage drop in a reasonably long cord. I would check for a loose or poorly connected neutral somewhere. If it's a 30A (or 20A) outlet you're ultimately connected to, that would pretty much have to be at the panel input or, if wired from a subpanel, in the feed from the panel to the subpanel. If it's a 50A circuit feeding you, it could be anywhere from within the RV back.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
