lawrosa
Jun 18, 2018Explorer
I can do that tomorrow. But the house is sold and Im moving out in 15 days.
I am 1200 ft off main highway and have I would presume several step down transformers on the poles outside. I have one right on the pole outside the home.
I did have a main neutral issue 12 years ago at the service entrance. When I had that breakers were tripping randomly. There were two old 1950 splices on that entrance. Poco cut them both off and crimped a new single butt splice. That tool he had looked like the jaws of life.
Would the higher power have anything to do with it being hot in NJ and so many a/c's running? Do they up the power?
Or do you think its in my panel?
Just odd that one breaker to shed has higher voltage then outlets in home. You would think I would read 136 volts also on one of the outlets on the same leg in the home..
Its all new square d service installed 2001... 200 amp..
Well water so ground rod outside
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
