Sprintervanmom's avatar
Jul 29, 2021
Power issues 2018 AmericanCoach MidwestPatriot
Has anyone heard of this issue with a Midwest Patriot by American coach (Mercedes sprinter 2017 body) ? I only had 5000 miles in it when I purchased it.
When you turn on the generator and the AC, the battery gradually loses power (I can watch the voltage dropping) and then the inverter starts giving e1 and e5 error messages and then the voltage drops low enough to shut of the thermostat to the AC. I’ve tried calling Midwest with no return call.
My Rv tech tried to install a piece that would at least allow the engine battery to charge the cabin battery but once he opened everything up he was baffled by the wiring in the Mercedes and didn’t want to risk messing anything up.
hate to put in a new generator or inverter and it seems this a manufacturing defect that the system is under powered. I should be under warranty to but can get no help from Midwest after leaving messages (should I be calling someone else?) any help would be appreciated!
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
