wa8yxm
Jan 30, 2018Explorer III
Look for a flat black plastic panel.. Basement or outside compartments. Inside anywhere.. Alas I think there is a contest to hide things like this.
Final option woudl be a device called a "Tick Tracer" this is a Radio transmitter with clip leads. you unplug from shore power. clip it to the water heater's power leads at the relay.
Then using the receiver you swing it past the wire. You will hear a BEEP as the "Wand" points to the wire. Well follow the beep. when it ends. you are pointing at the power panel.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
