a__serrano's avatar
a__serrano
Power Tech Generator
I have a diesel Power Tech Generator that will not start. Can you tell me what may be the problem?
    Wow! - Brings new meaning to...."trouble shooting"
    "I have a diesel Power Tech Generator that.....etc."
    OK - step number one:
    Do you still have it?
    Check to see if generator is still "on board"....:W...:h
  • The manual will give you a flow chart for trouble shooting in the very back. I have found it very useful.
    Will not crank.
    Crank no Start.
    Start will not run.
    The manual is available online at PowerTech's web site.
  • considering your screen Handle ?
    my uncle has a 2010 serrano, not sure of the model genset
    but it does have a pre heat feature
    push the button, wait for the light to go out, then crank it over
    watch for the light, your preheat might not be working,
    it won't start without the pre heat
    No.
    No matter how much I try I just can't get enough info out of "will not start"..
    For an diesel engine you need three things.. Fuel, air, compression.
    Do you have fuel?
    So does it crank (rotate, turn over, move) when you try to start?
    Does it have glow plugs, are they working?
    And so on..
    Fair chance you have a fuel problem if engine turns over with no start.. Try a new fuel filter if that is the case..
  • A model number would help- along with more info. Does it crank but not start, not crank at all, or crank slowly?
    Power Tech has a list of manuals here, and the manual for the PT8, PT10, and PT12 is here, and it has some troubleshooting flow charts in it.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
