Livies_Dad's avatar
Livies_Dad
power window doesnt work
05 ford e450 Class C--Power window on passenger side wont work.
Doesnt work off master switch or switch at passenger door. Does not even click. I would guess there is only two things- switch or motor.
Drivers side window works fine. My question is -how do you get the door panel off?
Any help appreciated.
  • Try researching the issue on Ford-trucks.com. I seem to remember seeing posts about this and the issue being dirty contacts on the control unit (driver's door).
  • I would suggest taking it to a service center. The new windows are as simple as putting it back on a track. You usually have to replace the entire assembly.
    UNLESS it is just a fuse. Look in the fuse box diagram for one that says passenger window.
    Try pulling up on the panel, once you have the bolts out.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
