HelloImDavid's avatar
HelloImDavid
Power Windows dont work
I took the Battery Terminals off to clean then hooked them back up again. I examined the Circuit Breaker plug in Module for the Power Windows in the Fuse Panel and I get continuity across its two pins. There is no independent fuse that's labeled 'Power Windows' ... just the circuit breaker module
Please help. Is there a procedure to reset the Power Windows ? Thanks.
2008 Coachman Class C. 21 QB model.
  • As I said, there is no Power Window Fuse listed in the chart ...just the CB is listed.
    But I shall see if there is 12 vdc at the CB. Im not prepared to rip into the door though..and id rather take it in and pay a Professional to fix it. Thanks. End.
  • This forum is FORUM technical support. Your post needs to be in Technical support. IF you have duplicated this post, then that is also not allowed per forum rules. If you made mention in another post, unless someone looks at your past posts no one is going to be able to know. Certainty I am no mind reader. Maybe other folks are.
    As to your question?
    If you have actually checked the fuse using a VOM and it is good, and there is a CB in the circuit, then you need to check voltage out of the breaker, IF you have voltage there, then move up he circuit to the next logical place, The switch. You need 12VDC into the switch for things to work. I would suspect you have a broken power wire where they feed through the door post to the door. Can be a common source of trouble.
  • donn0128 wrote:
    Get this in the right forum you might get an answer.
    What sort of vehicle?
    This looked like the appropriate Room for my question. If not..which Room is better ?
    I already listed the RV in my original Post. (Its a Chevy based Engine and Chassis. 6.0 litre).
  • Get this in the right forum you might get an answer.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
