Hybridhunter wrote:
So I just spent my first weekend camping where I am back to using the alternator in my F150 for power. The alternator is 220 or 230 amps, (not sure), and the engine is a 3.7 V6, with EPS. With no power steering pump, and small displacement, it idles very efficiently. I have ordered a WIFI OBD plug in, and I will report actual fuel used at a later date. It was able to run my 6000btu AC effortlessly.
I used fairly cheapo #8 AWG booster cables 12' long to connect the vehicle to one of my 2 batteries in the rear of my TT. From there, it goes #2 AWG hard wired to my 1500 watt inverter 12' away. The lowest voltage I saw at the truck was 13.4v when the cooling fans cycled. It idled near silently while powering my trailer. Running a 60-70 amp load off a 220 amp alternator shouldn't appreciably shorten its life IMO.
Everyone loves to say how inefficient this type of setup is, but my genset used .4 gph when powering the AC. An inverter gen would be more efficient. But I think spending $1K to save on fuel is donkey economics.
I really like the quietness, no extra fuel to haul, no genset to haul, no other campers bothered.
Thanks for your clear and very reasonable post!!
We're not afraid to idle our motorhome's V10 main engine as needed to charge our coach batteries and cool the motorhome when, for instance, eating lunch in crowded parking lots in scorching weather from the dash A/C. It idles very quietly - quieter from the outside than any small portable generator - and vibration-free through the floors inside the coach area.
BTW .... going back the the OP's first post .... you can install special large alternators on the main engine without having to use them at the RPM levels above idle. Just install an alternator with large enough amperage capacity such that at engine idle speeds it still is putting out the power you need. For instance, my Ford's V10 130 amp stock engine alternator - according to Ford's published RPM versus amperage curves - still puts out 60-70 amps with the V10 idling. This is enough for our needs, however what this means is that a huge alternator - say for example a 400 amp at 1300 RPM alternator - might put out in the neighborhood of 250-300 amps with the engine only idling. This is how I would size a large engine alternator for special use in an RV - get the size you need so the engine can be left at only idle RPM.
