SFVdave's avatar
SFVdave
Problem charging House Batteries
My 2004 Ford E-350 V10 Class C has developed a problem with charging the house batteries. I have a Xantrex Battery monitor. My house batteries are 2 Group 24 batteries brand new, 2 weeks old. because I thought they were not charging when driving. Found 2 bad cells and they were 42 months old.
So the house batteries were replaced. I was at a full hookup camp ground for 3 days and the batteries should have been fully charged. We left yesterday and drove 2 1/2 hours to another CG with full hookups. The Xantrex battery monitor showed full when we arrived. This morning after a night hooked up to shoreline power, I disconnected the shoreline power and went in to check the Xantrex battery monitor. It showed 85% and 12.4 volts. I hit the wall panel tanks/propane and battery switch and it showed 2/3's. that's crazy, it should be full and 12.6 volts. I started the engine and it showed 14.2 volts and 10 amps on the Xantrex battery monitor and full on the wall panel of gauges. I drove for 6 hours and when I got home, it was 12.6 volts, fully charged.
Before I changed out the batteries, It would be fully charged when I pull out of my driveway and be down 10-15% after getting to the CG 6 hours later. Do I have a bad switch somewhere or could my converter charger which is an Intelli Power 45 amp with the charge wizard be the problem? How do I test?
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
