jlscjs's avatar
jlscjs
prodigy brake controller ( I need help)
I have a prodigy brake controller and lately I have not been feeling the trailer brakes being used. I tried to set the control by moving the lever all the way to the left and turning the left dial to 6volts. When I do this it reads 12volts to start with then counts down to 0volts, I cannot set it at 6volts, is this a result of a bad controller? I've tried numerous times to follow the book to set it to 6 volts but no luck, also when I crawl underneath to test the current on the wiring I'm showing nothing,
  • First thing I'd do: With the trailer hooked up, I'd pull the emergency cable pin out and make sure the brakes are locked up which will take them out of the trouble shooting equation. If not, you might have a brake or wiring problem on the trailer itself.
    If you need more instruction on how to do this, let us know.
Having RV issues? Connect with others who have been in your shoes.24,260 PostsLatest Activity: Jun 07, 2025
