kaydeejay
Jul 20, 2014Explorer
I doubt you have a Prodigy issue.
More likely you have a short in the trailer wiring which will cause both error messages.
If the wiring passes through the axles there is a good chance it has chafed and is shorting inside the tube.
Replace the brake wiring and run it OUTSIDE the axles, held by zip-ties or similar.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
