DAS26miles wrote:
Checking with PD intelli-power and says it works with AGM's.  Looking at Duracell Utra Platinum Group 27 AGM's.  $220 each less 10% ordering online and picking up.  Not too bad.  Just the 92ah I don't care for. I was hoping for 100ah but if it recharges 5 times faster, it shouldn't make a difference.  I was using my generator for and hour in the morning and 2 hours in the evening and still down 10 accumulating amps per day.  Solar only kept it from dropping any further in daytime.  But by third day I was down 30 amps on the third evening after charging.  I'm hoping that the AGM's will get it charged back closer to full.  I know part of the issue is the PD Intelli converter chgarger  claiming to get the batteries up to 90% within 2-3 hours and another 15 hours to fully charge.
Say you head out with a full pair of 27s at 180AH.  You don't need to recharge until down to 50%.
If you need to run the gen for an hour next morning, that means you used 90AH.   So you do a 50-80. 30% of 180 is 54 AH.  Can you get by till morning?   Doesn't look too good if you use 90.
If you do the 80-90 another 10%, that's 18AH more for almost another hour of gen time, so you replaced 54+18= 72AH.  Not enough to be above 50% next morning.
You need more battery!  Get two 6s instead of two 27s.  Bank is now 225AH, leave home with that and next day down 90 to 60%, and do a 60-80
So up 50AH and at 80% or 180, and do another day of 90, now down to 90/225= 40%  Now you need some gen time for the morning of the third day.  A 40-80 is 40% or 90AH so back in business.
Do 40-80s.  How often?  A couple more days, no big deal going just below 50%.  How many times a year?  Or do a 40-90 and then a 50-90.
From the OP's description, besides other issues, it looks like recharging by gen when already above 80% so a low amp, long time recharge to get not many AH restored.  That is why they invented the 50-80, so as not to waste gen time.  Recharge down in SOC where the batts can accept all the charger's amps.
